Many people do not know how to choose when buying a TV. In fact, as long as you determine these three things, you can choose the most suitable TV for you.
Different prices for different TVs. If you first set a budget range to buy a TV, you will save a lot of time comparing TVs. Usually, there are only 2-3 cost-effective TVs in a price range. After confirming your TV budget you can list all the best TVs, so you can choose the most suitable TV for your family.
From the current TV market, large-screen TVs are the future trend. So I suggest that you try to choose the largest size TV that you can accept if the conditions allow. The viewing experience of a large screen TV is far from being comparable to a small screen TV, and it is also atmospheric to put in the living room. You can calculate the specific length of each TV size in the TV Size Calculator.
What are your needs for the TV? Do you just want to watch TV or do you want to play games on TV? Different needs for different types of TVs. If you simply watch TV, you can choose a TV with a true 4K, a large screen, a processor at least quad-core A55 or above, and a memory 2GB or above. If you want to play games, you'd better choose a TV with HDMI 2.1 interface and 120Hz refresh rate. Specifically, refer to Gaming TV Buying Guide if you want to buy a game TV.
This is the most basic guideline for choosing a TV, you need to specify the budget, size, and requirements, then you can choose the most suitable TV.
1. What's your budget?
2. What size do you prefer?
3. What are your requirements for TV?
