Are RAM and ROM important for TV?
BigZ
Smart TVs and TV boxes have more and more functions now, and many users want to install more apps or other content, therefore the memory of TV is quite important.
So what are RAM and ROM?​
RAM is the memory used by the TV to run programs in the system, and after opening more software the system will lag and die due to a lack of memory. Therefore, it can be understood that the running memory of the TV is an important reason for causing the TV lag or not.
ROM, generally used to store programs and data, is like a small warehouse for the TV. Using cell phones as an example, when the phone downloads too many APPs, it will prompt a lack of storage space and lag. So as the same for TV, there will be a variety of large-screen APP data is saved on the TV, if the storage space is too small, the corresponding data can be downloaded and stored are too little too. The TV will lag due to a lack of memory in the future.
Will more ROM be better?​
When we buy a new TV, we will open the settings to find that it is obviously a new machine, but the memory is already partially used up. This is because the system of the TV and TV box is installed in the ROM of the TV and box, but after booting, there will be many system programs running at the same time, taking up a certain amount of running memory.
Every time you run a program, the CPU of the Android system will cache and read the files one by one, so the larger the memory, the higher the corresponding smoothness of the TV. So for the Android system, the large memory correspondingly can solve the problem of TV or TV box lagging, and there is enough space when running multiple programs.
Is large memory the most important thing?​
A good TV and TV box, should not rely only on memory to distinguish, the most important is the processor.
