Mialulu
Are TV mounts universal? This is a question that many people often ask. Some say yes or not. In fact, both are not completely correct. The TV mounts are divided into special mounts and universal mounts, and they should be purchased according to their situations.
There are two types of TV mounts: dedicated mounts and universal mounts. Dedicated mounts can only be installed with a specific model of TV. General mounts are divided into three sizes with different specifications. You should choose according to the size of your TV when purchasing.
Under normal circumstances, TV mounts can be universal. The prerequisite is that the screw hole distance on the back of the TV for installing the bracket cannot exceed the maximum hole distance range of the TV stand. Let's take a look at how to determine the screw hole distance of the TV.
Turn the TV over and you will see the screw holes on the back for mounting, generally, there are 4 holes, and some are 2 holes. Measure the distance A between the two screws horizontally, and measure the distance B between the two screw holes vertically. As long as the distance between A and B does not exceed the maximum hole distance range of the mounts, it is universal, even for different brands and models.
There is something we must pay attention to when installing the TV mounts.
First, we must distinguish the types of flat-panel LCD TV mounts. Now LCD TV mounts on the market are mainly divided into the adjustable angle and fixed angle mounts, original LCD TV mounts and flat panels sold separately LCD TV mounts. And the fixed mount is hard to modify once installed.
Secondly, when installing the flat-panel LCD TV mount, you should fully consider that somedays you need to repair and maintain the LCD TV, which means that it should facilitate disassembling and will not damage the wall and the surface when repairing. In short, whether it is a fixed or adjustable mount, it is necessary to ensure that the LCD TV is convenient for disassembling.
Third, flat-panel LCD TV mounts, fasteners, and metal parts that may adversely affect safety and environmental protection must be firmly welded or connected. And it must be treated with anti-rust, and other materials should have sufficient anti-rust ability. If you make amounts frame by yourself, its carrying capacity should not be less than 4 times the actual carrying weight.
So, are TV mounts universal? Most of yes, as long as you didn't have the special mounts.
1. Are TV mounts universal?
2. How to install TV mounts?
