Stefani
With the diversification of office model, have been used by more and more business projectors, whether subordinates reporting and leadership, the joint work between different departments or the cooperation between customers, you need to use the projector, and traditional business projectors at the connection, debugging, there is a lot of limitations, use rise very inconvenient, and business intelligence projector, because the advantages of the operation is simple, easy to use, clear record the use of the projector is gradually replace the traditional commerce, BenQ, as well-known projector brand, have comfortably in the DLP projector market for 10 years, Launched a lot of hot style intelligent home projector and intelligent business projector, BenQ E500 is one of the best.
BenQ E500 projector overall appearance is white, the size is 283 mm * 95 mm * 222 mm, weight is 1.9 kg, with a small, lightweight to describe it a little too much, even though the girl can easily carry it, when using, projector produces a great quantity of heat, so, for heat dissipation problem of the projector has always been a concern for users, after all, the inside of the projector circuit element relative to "fragile", bear high temperature, which BenQ E500 in left and right sides of the design of the grille of large area, can be the heat generated by the rapid spread out of the machine, to ensure the normal use of the projector.
BenQ E500 projector front lens not shielding cover, lens dust or lens scratches easily, suggest to add, the lens is all glass, low dispersion coating lens, this lens biggest advantage is to use for a long time also won't empty coke, on the service life of the light bulb, the adoption of exclusive smart power-saving technology SmartEco ®, can automatically adjust the light bulb, energy consumption on the basis of the guarantee work 4 hours a day, you can use for a decade, long affection accompanied but rare in other projection.
In BenQ E500 projector has a physical buttons upper area, including: power button, menu, signal source key as well as the return key, because of the remote control so you can use these buttons are generally very few, this is designed to prevent the remote control suddenly without electricity will not affect the normal use of the projector, is not redundant, in the button on the left by a focusing knob and focus knob, can both cooperate will display a clear projection screen, the coke ratio of 1.1 X.
Unlike traditional projector, in be used actually, BenQ E500 only need to connect the power cord can be used, after entering into the interface, you can see there are three kinds of projector screen mode, respectively is directly screen, computer screen, mobile phone screen, here I'll demonstrate mobile phone screen and computer screen, first of all, find Miracast, then find a wireless display in the mobile phone set, the connection can be used, is very simple, even in the absence of wifi, BenQ E500 also support wireless hotspot function, wireless connection equipment for screen, adapt to the different environment.
Computer screen is much more simple, direct connect VGA line on the computer, select the “computer/YPbPr”, BenQ E500 is a commercial projection, even if only XGA document for work or a PowerPoint presentation or competent enough, pay more attention to the brightness and contrast, commercial projection are both BenQ E500 have, let's take a look at its projection effect, can see the projection effect is very good, 3300 lumens even in the absence of the curtain the projection on the wall can also be very clear, have administrative levels feeling.
13000:1 contrast allows BenQ E500 projectors to project a clear picture quality no matter in a white or black environment, even small text can be projected very clearly.
In general the BenQ E500 was very good, as a business office the projector with the intelligent, portable, wireless for the advantages of the screen, the operation is simple, high brightness 3300 lumens and 13000:1 contrast to make it even in the daytime screen can also is very clear, the color performance, heat and noise are acceptable in the office environment, the overall performance is a qualified office projection.
