reality
BenQ HT711 is a new BenQ projection product recently. When I saw its appearance, I immediately thought of BenQ E580. It really looks like it, and it can be said that it is an upgrade of E580. BenQ HT711 added intelligent voice remote control function, the content can be blurted out and the picture can be opened. The new human-computer interaction is more convenient for the elderly and children to operate.
The ultra-high pressure mercury lamp as the projection light source, the brightness reaches 3500 lumens, can present a bright picture quality level; Lens support 1.3 times zoom, in 2.5-3.3 meters can project 100 inches of super screen, suitable for most home environment; At the same time, trapezoidal correction is also supported, and the side cast can be perfectly realized, eliminating the space limitation. In addition, BenQ HT711 carrying BenQ Cinematic Color professional film Color calibration technology, see the BenQ from beginning to end and implement Rec. 709 international standard Color domain determination, each a BenQ HT711 do nearly 99% coverage.
On the display chip, BenQ HT711 USES a 0.65-inch DMD chip from Texas instruments, providing original 1080P hd quality, better square pixels, better detail, and lifelike images. The ultra-high contrast ratio of 50000:1, from black to grey, the dark field of the picture is no longer black, can restore the wonderful details of each frame.
In terms of functions, BenQ HT711 supports wireless screen projection function, supports Mircast android device connection, easily connects with mobile phones and multiple screens, is equipped with 5G wifi network connection, supports bluetooth function, and has 2D to 3D function. The interface is also relatively rich, with one HDMI interface, two USB interfaces, MINI USB interface, rs-232 interface, audio output interface and video output interface.
BenQ HT711 projector from the configuration, function, technology and other aspects are a relatively strong projector products, strong practicability, comprehensive function, high technical level, can be fully applicable to home and commercial environment; In addition, BenQ HT711 projector also formed a family entertainment X series combination for sale, the price will certainly be higher, the budget of the Internet users can consider, the entry level or the pursuit of general projection users are not recommended to join in.
