Adney
BenQ launched the 4k Laser Projector V7000i/V7050i this year. It makes up for the lack of smart TV features in its first 4K laser TV, the V6000/V6050. BenQ V7050i laser projector added Android TV function which allows consumers to truly use laser TV as smart TV and enjoy a variety of audio and video entertainment.
Projection System | DLP | Horizontal Frequency | 15K~135KHz |
DMD size | 0.47" ECD | Vertical Scan Rate | 23~120Hz |
Main Marketing Series | Home Projector | HDTV Compatibility | 1080i,1080p,2160p,720p |
Product Features | 4K,white ID,UST Laser TV, Google Android TV | 3D Compatibility | Frame Packing (Blu-ray),Side by Side (Streaming),Top Bottom (Streaming) |
Native Resolution | 4K UHD (3840×2160) | HDMI in | HDMI-1 (2.0b/HDCP2.2),HDMI-2 (2.0b/HDCP2.2) |
USB Type A | USB Type A-1 (2.0/Power Supply1.5A),USB Type A-2 (3.0/Power Supply1.0A),USB Type A-3 (2.0/Power Supply2.5A) | ||
Native Aspect Ratio | 16:09 | RS232 in (DB-9pin) | (x1) |
Brightness (ANSI lumens) | 2500 | Speaker | (x2),5W Chamber |
Audio in (3.5mm Mini Jack) | (x1) | ||
Contrast Ratio (FOFO) | (w/ Lightsource Dimming),2,000,000:1 | Audio L/R Switch | Yes |
HDMI Audio Return | Yes, ARC, 2 channel | ||
Selectable Aspect Ratio | 16:9,4:3,Auto,Real | Power Supply | AC 100 to 240 V, 50/60 Hz |
Display Color | 30-bit (1.07 billion colors) | Typical Power Consumption (110V) | 480W |
Light Source | Laser | ||
Light Source Wattage | 152W | Stand-by Power Consumption | <0.5W |
Light Source Life | 20000 hrs | ||
Throw Ratio | 0.252 | Acoustic Noise (Typ./Eco.)(dB) | 34/29(Typ./Eco.)(dB) |
Zoom Ratio | Fixed | ||
Lens | F=2.0; f=2.45mm | Operating Temperature | 0~40℃ |
Projection Offset (Full-Height) | 149% | Android TV dongle | QS01 |
Keystone Adjustment | 1D, Vertical ± 30 degrees | ||
ANSI Uniformity (Min.) | -40% | Remote Control w/ Battery | RCI067,RCV024 |
Clear Image Size | 70"~123" | User Manual CD | 1 (27L) |
Image Size | 70"~123" | 3D Glasses | (Optional),DGD5 |
Picture Modes | 3D,Bright,Bright Cinema,DCI-P3,FILMMAKER MODE,FILMMAKER MODE HDR,HDR10,HLG,Silence,User 1 | Quick Start Guide | 1 (21L) |
Color Wheel Segment (SSI) | RGBRGB | Warranty Card (by region) | Yes |
Color Wheel Speed | 2X (50Hz),2X (60Hz),3D (120Hz) | OSD Language | 28L |
Rec. 709 Coverage | 96% | Dimensions (WxHxD) (mm) | 500 x157 x388 |
DCI-P3 Coverage | 98% | Dimensions (WxHXD) (inch) | 19 x 6.18 x 15.2 |
Input Lag | 83.34ms (1080p@60Hz) | Net Weight (kg) | 9.9 (+/-0.1) |
Resolution Support | VGA (640 x 480) to 4K UHD (3840 x 2160) | Net Weight (lb) | 22 |
