Mialulu
When choosing the best projector under $800, you must consider characteristics such as lamp type (laser or bulb), DLP or LCD, short or long focus projection, resolution, projection size, etc. In addition, you must also consider factors such as image quality, price, and ease of setup. There are the 5 Best Home Projector under $800.
1. ViewSonic PX727HD
ViewSonic PX727HD is one of the top projectors on the market, and it is the perfect solution for anyone who needs to buy a high-quality projector at a very affordable price. It is one of the most advanced high-definition projectors on the market, and the picture is very clear. It has very powerful built-in features and provides a one-year limited warranty.
2. Optoma GT1080HDR
If you want to buy the best projector on the market under $800, then Optoma GT1080HDR is a good choice. The features and specifications of this projector are great. This model provides full HD (high definition) images.
In addition to providing excellent video quality, Optoma GT 1080HDR also provides users with excellent image quality through the use of a full range of technologies. In addition, users will appreciate the almost flawless black on the projector display when watching high-definition videos or photos.
3. BenQ MH733
BenQ MH733 has a larger screen than traditional projectors, and it has a special lens that helps improve image quality. This projector is very cheap. You can easily save hundreds of dollars just by using this projector.
In general, this projector is very suitable for new users who want to experience the BenQ experience because of its high resolution, contrast, and brightness. Whether you are a professional user or a beginner, this may be one of the best projectors you can buy under $800. So give yourself one now and start enjoying the best visual effects the movie has to offer!
4. Optoma HD28HDR
If you are looking for the best projector for your home theater system that costs less than $800, then check out Optoma HD28HDR. In its price range, it has the same image quality as other high-end projectors, but the cost is not as good as other projectors. It also provides a two-year limited warranty, even if the price is slightly more expensive, it is also very good value for money.
5. Optoma HD146X
The Optoma HD146X is one of the best projectors on the market and is recommended as a top model in the HD projector world. This device has many features that make it very attractive to consumers, for example, this system comes with a one year warranty.
With the Optoma HD146X projector, users can enjoy the crisp colors offered by today's top models, along with the brilliant picture quality associated with the best HD sources.
- Resolution: 1920x1080
- Contrast Ratio: 16:9 (HD)
- Brightness (Lumens): 2000
- Screen size: 30" - 300"
- Support 3D images
- Powerful 10W speaker
- 20,000 hours
- Remote is not backlit
- Don't support USB type-A
2. Optoma GT1080HDR
- Resolution: 1920x1080 |
- Contrast Ratio: 50,000:1
- Brightness (Lumens): 3800
- Screen size: 36" - 306"
- 15, 000H of usage time
- Supports 4K
- No USB type-A power
- Not easy setup
3. BenQ MH733
- Contrast Ratio: 16,000:1
- Brightness (Lumens): 4000
- Colors are very bright
- Zoom
- Full HD support
- Not durable
- Not high quality
4. Optoma HD28HDR
- Brightness (Lumens): 3600
- Screen size: 28" - 301"
- 3D compatibility
- Excellent HDR
- Dynamic Black technology
- Fan is noisy
5. Optoma HD146X
- Contrast Ratio: 25,000:1
- Quiet fan
- Easy installation
- High brightness
- Speaker isn't good
