Dangbei F1C Projector Outside View-Differences with Dangbei F1
Celine2020
In the past two years, the developing trend of smart projector is obviously making this "illusion" gradually come to reality. After all, whether it is AI or artificial intelligence or advanced elements such as IoT, the effect display on smart projector is not worse than that of smart TV, and because of the inherently small body of smart projection, large screen, portable, young industry, etc.
As with smart TVs, only brands that have survived the industry ’s big waves will be able to provide users with more attentive products. This year ’s Dangbei, which has earned its reputation in with the F1-led smart projector matrix, has become well deserved dark horse in the industry. Dangbei has launched a new generation of flagship products- Dangbei F1C Projector . The external design and internal performance of this Dangbei F1C Projector:
Outside view
From the modeling point of view, the Dangbei projector F1C and the Dangbei F1 come out almost immediately. The combination of the classic space gray ABS plastic material and the dark gray mesh cloth, the flat body design, both home and business The style, whether it is placed in the home or the company's meeting room, looks low-key and harmonious.
Looking closer, the Dangbei projector F1C is mirror-symmetrical like the F1. The lens is placed on the left, and the stitching fabric and Dangbei logo are placed on the right. In addition to the different left and right designs, the focus camera in the center of the front of the projection has changed from a single lens to a long strip. This is one of the highlights of this functional upgrade.
When you see the Dangbei projector F1C, you can directly focus on the lens at first glance. When the Dangbei projector F1C uses a sapphire glass protector and a lens that can achieve dynamic thermal compensation, the sealed silica gel isolates the dust, which greatly guarantees the light permeability. When Bay Projection F1C did not blindly pursue higher brightness, returning to the real needs of family viewing, the brightness of 1300 ANSI lumens is enough to ensure the daily use of users.
Under the goggles in the middle of the front face of the projection, there are dual TOF laser modules and CMOS camera modules. Through dual algorithms, laser autofocus can be achieved, and this autofocus can be instantly clear , Fast and does not interfere with the user's experience watching movies. At the same time, combined with the application of ichips image processing chip and acceleration sensor, Dangbei projection F1C can also achieve global fast and unperceptual correction of the picture to cope with various complex use scenarios.
The side is the same fence design as F1, and it is still a structure with ventilation on one side and heat dissipation on the side, but when the Dangbei projector F1C uses a shorter and thicker pure copper heat pipe and a larger area of fins, the air duct design belt Comes with more efficient heat dissipation and quieter fan noise. According to the evaluation, the fan sound is hardly felt in the movie, and the heat dissipation is indeed good. The temperature at the heat dissipation port is maintained below 40 ° C, which reduces the damage to the lens and the body.
The back is also a very familiar design, power switch and a row of interfaces, from left to right are the headphone jack, LAN interface, HDMI2.0 interface and USB3.0 dual interface and power interface. Fortunately, when the Dangbei projector F1C still retains dual USB3.0 interface, to ensure a smooth experience of external devices to transfer data.
When the top of the Dangbei projector F1C can be said to be a streamlined ultimate display, there is no modification except for the original appearance of the fuselage splicing.
The bottom of the fuselage is similarly concise, with removable screw pads at the four corners, the threaded opening of the mounting bracket at the center and the tab page with basic product information. The classic design composition naturally has the Dangbei remote control with magic side keys, familiar formula and familiar operation.
