Dangbei Projector
Dangbei f1 and f1c are the projectors released by Dangbei projection at the beginning and end of 2019, and 2019 is also the first year of Dangbei technology as an intelligent projector hardware device. The f1 and f1c projectors are in the picture quality and technology Each level has its own absolute advantages. At the same time, Dangbei f1 and f1c also have the common advantages of high configuration, good system, large memory and fast operation. When the actual difference between shell f1 and f1c needs to talk about the appearance, image quality and focus correction technology.
the appearance of the f1 and f1c is different:
f1 lens is on the left while the f1c lens is on the right , which means that the optical machines of f1 and f1c are different. The location of the "dangbei" logo also happens to be the opposite design.
In addition, in the focus lens between the lens and the logo, f1 only has a larger focus lens, and f1c has a set of focus modules, has a dual TOF + CMOS camera, uses laser autofocus technology , focusing speed is faster, performance Show the technical advantages of f1c.
When the difference between F1 and F1C focus correction technology:
Because F1C adopts the latest laser focusing technology and has dual TOF + CMOS camera modules, it has advantages in focusing speed and accuracy . How fast is the focusing speed of f1c? Many projectors will have a focus map reference when focusing, and f1c achieves sensorless autofocus, and no longer uses the focus map as a reference when focusing. In addition, when F1c realizes automatic trapezoidal correction, f1c enters the side projection mode, the screen will be automatically corrected to the square image display, and the entire correction process no longer requires manual operation.
As a projection product released in early 2019, f1 will be inferior to f1c in focus correction technology , but the focus of f1 can also be accurate and fast, and it can also support trapezoidal correction and side projection mode , but the correction process requires Fine-tune the picture manually. However, when Bay Projection broke through the two major problems of the trapezoidal correction and autofocus of the projector within one year, the technology is indeed progressing rapidly. Currently, the only projectors that support automatic keystone correction technology are XGIMI, Shenhua, and Dangbei, while only Dangbei supports non-sensing focus.
the quality of the f1 and f1c is different:
when the brightness of the f1 and f1c is different, the look and feel will have different effects. The f1 brightness is 1400 ANSI lumens, the f1c brightness is 1300 ANSI lumens , and the higher brightness of f1 will affect the quality of the projected picture. With rendering power, f1 will look slightly better than f1c in a lighted environment. In terms of contrast, Dangbei f1 has a high contrast of 8001-10000: 1. In the contrast of the picture, the image of Dangbei f1 has a more vivid experience. As for the display chip, when F1c uses 0.33DMD display chip, when F1 uses 0.47DMD display chip , the resolution can reach the level of 1080P, but the way of implementation is different. This is also the reason why the prices of f1 and f1c differ.
Dangbeif1c is priced at more than $500 , it is already a super high configuration in this price range. It is difficult to find 3,000 ANSI lumens, 3 + 32GB of large memory, support for non-sensory autofocus and keystone correction Smart projection products. Obviously, when F1 still maintains the advantages of its own flagship configuration, F1C is a more cost-effective and more affordable smart projection product .
