Bread Pitt
If you are having trouble with your Hisense 75H8G TV, first try turning it off and on again. If this does not fix the problem, check the tips in the following statements:
1. Hisense 75H8G TV No sound or picture
3.When I turn on my Hisense 75H8G TV, there is a delay for a few seconds before the picture appears. Is this normal?
4.The picture is normal but there is no sound
5.Sound but no picture or black and white picture
• Check if the power cord is plugged into a powered AC outlet.
• Press the Power button on the remote control to activate the unit from 'Standby' mode.
• Check to see if the LED light is on or not. If it is, then the TV is receiving power.
2.I have connected an external source to my Hisense 75H8G TV and I get no picture and/or sound. • Check for the correct output connection on the external source and for the correct input connection on the TV.
• Make sure you have made the correct selection for the input mode for the incoming signal.
• Yes, this is normal. The TV is initializing and searching for previous setting information.
• Check the volume settings.
• Check if 'Mute' mode is set to On.
• If the picture is black and white, unplug the TV from the AC outlet and replug it after 60 seconds.
• Check that the Color is set to 50 or higher.
• Try different TV channels.
