Robert
The laptop can be connected to the Xming Q1 Pro projector by wired connection and wireless connection.
Wired connection
1, select the connection cable
Choose HDMI cable, as the transmission cable to Xming Q1 Pro. Xming Q1 Pro has a HDMI port.
2. Connect the device
Connect both ends of the HDMI cable with the Xming Q1 Pro projector and the HDMI interface of the laptop respectively;
3. Start the projection
Turn on the projection function of the laptop, choose only the first screen, the second screen, copy or expand any way
Wired connection
