How to Add Apps to LG Smart TV? Easy Steps
Just bought a new LG Smart TV or want to customize it with your favorite apps? Adding apps to your LG Smart TV is easier than you think. Whether you want Netflix, Disney+, or niche apps, this guide will show you how to add apps to LG Smart TV step by step.
Let’s dive in!
Quick Answer: How to Add Apps to LG Smart TV​
To add apps, go to the LG Content Store on your TV, browse or search for the app you want, then click Install. You’ll need an LG account and an active internet connection.
Now let’s walk through the full steps.
Step-by-Step Guide: How to Add Apps to LG Smart TV​
Step 1: Connect to Wi-Fi​
Make sure your LG Smart TV is connected to the internet.
  • Press the Settings (⚙️) button on your remote.
  • Navigate to All Settings > Network > Wi-Fi Connection.
  • Select your home Wi-Fi and enter the password.
Step 2: Open the LG Content Store​
  • Press the Home button (🏠) on the remote.
  • Scroll and select LG Content Store from the menu bar.
Tip: If you don’t see the LG Content Store, ensure your TV’s region is correctly set under Settings > General > Location.
Step 3: Browse or Search for Apps​
Once inside the LG Content Store:
  • Use the Search icon (🔍) to look for a specific app (e.g., “HBO Max”, “Spotify”).
  • Or explore Apps > Categories to browse available apps.
Step 4: Install the App​
  • Select the app you want.
  • Click Install.
  • Wait a few seconds while it downloads.
Once installed, the app will appear on your Home screen under My Apps.
Bonus: How to Rearrange or Delete Apps​
To customize your Home screen:
  1. Press Home.
  2. Navigate to the app you want to move or remove.
  3. Long-press the OK/Enter button on the remote until the edit mode appears.
  4. Use the arrows to move the app or press the X to delete it.
Common Issues & Fixes​
Why can't I find certain apps on LG Smart TV?​
  • Your TV might not support that app due to region or model.
  • Try changing your TV's region under Settings > General > Location.
  • Consider screen mirroring from your phone if the app isn’t available natively.
Can I add 3rd-party apps on LG Smart TV?​
LG Smart TVs (running webOS) do not officially support APK files like Android TVs. However:
  • You can use web browser access for some services.
  • Or connect external streaming devices like Fire TV Stick, Roku, or Apple TV.
Here are some top apps available on LG Smart TVs:
CategoryPopular Apps
StreamingNetflix, Hulu, Prime Video, Disney+, HBO Max
MusicSpotify, TIDAL
SportsESPN, FuboTV
NewsNBC News, CNN Go
UtilitiesPlex, YouTube
Final Thoughts​
Now you know exactly how to add apps to LG Smart TV — whether it’s streaming, music, or utility apps. Just follow the steps using the LG Content Store, and customize your smart TV experience easily.
Recap:​
  • ✅ Use the LG Content Store to add apps.
  • ✅ You’ll need Wi-Fi and optionally an LG account.
  • ✅ Can’t find an app? Try changing your region settings or using external devices.
Related Reading:
Can You Clear the Browser on an LG Smart TV? Step-by-Step Guide
LG Smart TV Not Connecting to Wi-Fi Troubleshooting Guide
How to Restart LG TV? Easy Guide
