How to-adjust the best color temperature on Vizio TV?
Xmint
Vizio TV can be adjusted to suit your preferences and viewing conditions. Adjusting the color temperature changes the white balance of the picture. How to-adjust the best color temperature on Vizio TV?
To adjust the color temperature: Menu > Picture > More Picture > Color Temperature
Use the Navigation buttons on the remote to highlight a color temperature preset
and then press OK.
Normal — Optimized for television viewing.
Cool — Produces a blue-hued picture.
Computer — Optimizes the picture for use as a PC monitor
Adjusting the Picture Mode Edit Settings
Picture Mode Edit Settings allow you to make precise adjustments to the picture.
To adjust the Picture Mode Edit settings:
Menu > Picture > Picture Mode Edit
Use the Navigation buttons to highlight the setting you wish to adjust, then press OK to change the setting:
• Save Picture Mode — Save a custom picture mode.​
• Lock Picture Mode — Prevent changes to custom picture modes.​
• Reset Picture Mode — Reset the picture mode settings to factory default values.​
Only available on customized preset modes.
