SuperM
1. Turn on the projector
After commissioning and installation of XGIMI projector, connect the power cable, press the start button on the top of the machine, and wait for the projector to start up.
2. Remote control pairing
Then take out the remote control for pairing: put the remote control to XGIMI projector within about 10cm distance, align with XGIMI projector, and press and hold the "back" and "HOME" keys for 3 seconds, to complete the Polaris remote control pairing.
3. Adjust the volume
Once paired, you can open a movie and press the volume buttons under the remote to turn up or down the volume. The next time you adjust the volume, you can use the volume button directly.
