How to attach stand for Toshiba TV?
l1232
Here is the guide on how to attach a stand for Toshiba TV before you start using your TV.
CAUTION:
• Disconnect the AC power cord before installing a stand or a wall mount bracket.
• The display on your TV is fragile. Make sure the TV screen is not scratched or damaged by hard objects or from pressure.
• After the installation is complete, make sure the TV is steady on a table or firmly attached to a wall mount, before removing all protective film, if any.
How to attach the Toshiba TV stand?​
To attach the TV stand legs to your TV:
1. Carefully place your TV face down on a clean, soft, flat surface.
2. Insert the TV Base Stand into the bottom slots on your TV.
3. Use the screws provided to secure each stand tightly.
If your table is long enough to place the TV, then insert the legs into the screw holes 'A that are shown in the illustration. If your table is not long enough, then insert the legs into the screw holes 'B' that are shown in the illustration. Note that these two installation methods types cannot be mixed.
