Celine2020
How to build a home theater in 2020 Summer? After all, by the name of home theater in 2020, a large screen is essential. The main topic is the living room. A home theater is based on a projectors, at first, you need to make sure the throw distance. Generally speaking, if you wanna build a home theater in 2020 Summer: Choose 100 inches from the sofa about 3 meters away from the curtain, 110 inches around 3.5 meters, 120 inches around 4 meters, 135 inches around 4.5 meters, and 150 inches around 5 meters.
Things you need to build a home theater in 2020 Summer 1:
Media Player
The media player here refers to the signal source for the projector to play content, which is generally based on the TV set-top box, and is supplemented by content playback devices such as Blu-ray players, mobile hard disks, and NAS to build a home theater in 2020 Summer. The set-top box is mainly to meet the daily needs of watching TV programs, and the frequency of use should be the highest. The rest of the Blu-ray players and other devices depend on personal needs. After all, they are placed in the living room. Considering the needs of different members of the home, PS4, Switch, Xbox, etc. may sometimes be used as signal sources.
To build a home theater in 2020 Summer, it should be noted here that if 4K content needs to be played, no matter whether it is a player or a projector, it must meet the standard of 4K resolution to be able to watch 4K content normally, and there are certain requirements for the hardware.
Things you need to build a home theater in 2020 Summer 2:
Display equipment
It can be said that it is the core of the home theater, and the quality of the projector of the display device determines the quality of the overall picture of the home theater. Under normal circumstances, there is no special pursuit, you can choose the more mainstream 1080P resolution brand projector on the market, look at the shape you like, or have special functions, find out the special function points to choose.
Things you need to build a home theater in 2020 Summer 3:
Sound bar
It is often said that the headset is "listening below three thousand", so when it comes to home audio, it can be said to be a bottomless hole. Tens of thousands of surround stereo sound packages are just an entry; the combination of echo wall + subwoofer is just enough to be enough. . Of course, this is actually a ridicule among audiophiles. For our ordinary families, the echo wall + subwoofer is completely enough to bring shocking sound field effects. If the requirement is lower, even a Bluetooth speaker is enough to meet the sound demand.
Media Player
Display equipment
Sound bar
