How to change Samsung TV PIN
Quisktv
PIN is a specific password to access your Smart TV and is used for various functions. Most Samsung TVs have an option to set a 4 digit PIN to lock some of the settings and apps.The default PIN is 0000, and if you want to change or reset your PIN on Samsung TV, follow these steps.
1. Click the Home button on your Samsung remote.
Home button on TV remote
2. Select the icon Settings.
Samsung Smart Hub.
3. Choose General>System Manager.
System Manager
4.Select Change PIN.
Change PIN
5. Enter your current PIN number. The default PIN is "0000"
Enter PIN Number
6. Then enter your new PIN.
Change PIN Number
Now you have changed your PIN on Samsung TV.
