How to change WIFI on Xfinity TV box?
KL111
How to change the WIFI on Xfinity TV box? Many users don't know how to change the wifi if they change their network, because it needs to use the Xfinity xFi. Here is how to do it.
1. First, open the Xfinity app or visit xfinity.com/myxFi and log in with your Xfinity ID and password.
2. Then, jump to the Connections tab.
3. Select your network on the Xfinity app or select View Network on the xFi website.
4. Click Advanced settings.
5. Then select 2.4 and 5 GHz WiFi.
6. Select Edit next to the WiFi band you want to update.
7. Finally, select the new WiFi mode and/or channel settings, then select Apply Changes to save the new settings.
That's all for how to change the Wifi on the Xfinity TV box. Welcome to disscuss below!
