Bread Pitt
Welcome to our shopping guide dedicated to home theater . This guide explains in detail everything you need to know to choose your home theater . What types of speakers to choose for which place , power , brands , audio format and finally the connection . Before going into detail, here is the configuration we recommend for a Home Theater :
The type of 2.1, 5.1 or 7.1 speaker for a Home Theater?
It is the most important element to take into account . To put it simply, it's the number of speakers in addition to your subwoofer and your amp: 2, 5 or 7 . Of course, that depends on the space you are ready to devote to them, because home theaters can be bulky . They can also be wired , better solution not to suffer from a very slight loss of sound, but bluetooth will not require you to run the wires along the complaints to connect them to your amp.
The power of a Home Cinema amplifier is expressed in Watt RMS . It is generally understood for the majority of consumer models between 250 and 1200 watt rms .
We recommend taking a minimum power of 1000 w .
Which home theater brands to choose?
The 4 most popular brands in Home Cinema are as follows. They mainly come from television brands :
What audio formats for my home theater?
Several formats exist to reconstruct a sound of more or less good quality. Here we retrace the main and most used for this type of product. These formats depend on the Blu-ray player or television you are using.
Some home theater models have multiple audio formats. For these formats to be taken into account, the format of your files or Blue-Ray must be compatible .
- Number of speakers : type 5.1 minimum ( i.e. 2 front speakers, 1 center, 2 rear and one subwoofer )
- Rear speakers : wireless (Bluetooth) to avoid wires
- Power delivered : 1000 watt RMS
- Player Blu-ray : although less used, manufacturers include almost every time, a Blu-ray drive required in order to connect the speakers to each other , then to your TV. The configuration is as follows: the 2 front speakers, the central speaker and the subwoofer (subwoofer) are wired to the bluray player ( the bluray player being connected via HDMI to the TV ). The 2 rear speakers are connected by bluetooth (wireless).
- The 2.1 system will give you better sound than TV sound alone ( mostly suffering from basic sound with no effect and voices coming out poorly ). However it will offer less good spatialization of space than 5.1.
- The 5.1 system has become the standard today because it offers quality sound and allows spatialization of sound. 2 speakers at the front on the sides of the TV, 1 central speaker for the voices and 2 speakers at the back to fully immerse yourself in reproducing the acoustic effects ( wind, rain, storm, etc. ).
- The 7.1 system allows even greater immersion and is appreciated by cinema lovers because it provides 2 additional speakers placed on the sides of the TV. It allows you to immerse yourself a little more in the heart of the action. Some speakers point the sound upwards to make the sound reflect towards the ceiling.
- Panasonic
- Samsung
- LG
- Sony
- The Dolby Digital output there are over 20 years and has experienced multiple changes. it remains the reference currently with 3 channels at the front and 2 at the rear as well as a subwoofer.
- The Dolby True HD is called lossless, uncompressed sound and restores sound almost perfect to perceive a sound made worthy of the cinema without any loss of sound effect. He is the one we like the most and present on a lot of Blue-Ray discs.
- The Dolby Atmos adds a verticalization of the sound which thanks to loudspeakers located towards the ceiling give you the illusion that the sound moves and arrives from the 4 corners of your room.
- The DTS HD is an evolution of the DTS Digital Surround and contains 7.1 channels; It appreciably improves the audio quality by compressing the sound less and digitizes the latter on 20 bits against 16 for Dolby, with a bit rate of 24 Mbit / s. Produced by Spielberg in 1993 for the film Jurassic Parc.
