Vincent star
When shopping for audio-visual equipment, many people are caught in the dilemma of whether to buy a projector or a TV. The projector has a larger picture, while the TV is said to have better picture quality than the projector. In fact, with the development of projection technology, the projector picture quality is worse than TV has become a false proposition. As long as consumers pay attention to the following points, you can buy a projection product that does not lose TV picture quality at all.
For projector products, brightness is one of the key factors affecting the clarity of the projector imaging, under certain conditions, the higher the brightness of the product, which often means that the stronger the imaging capabilities, the less the projection screen is affected by light.
Today's high-end projection has broken through the traditional concept of projector 4K ultra-clear decoding, so that the projector resolution from 1080P into the 4K era.
After having the advantage of brightness and resolution, the picture quality technology is also a major key to the final imaging effect of the projector. In addition, users can use the projector with a curtain in the process.
1. Brightness
2. Resolution
3. Picture quality technology
