Bread Pitt
First of all, it is necessary to determine the installation method of the projector, whether it is a ceiling installation, a rear wall bracket placement, a desktop placement, or even an ultra-short throw projection method placed on a TV cabinet.
Most projectors are installed on the ceiling. According to the characteristics of the optical screen, you need to choose the reflective optical screen. This installation method can achieve the best results for the reflective projection screen, and if you choose the type Gray or black reflective optical screens can also play a good role in suppressing ambient light, and can achieve excellent projection effects in bright environments.
projection screen for the rear wall installation
If the projector is installed on the rear wall, or placed on the coffee table, or even the side of the room, as long as the line of sight area is within the reflection angle of the screen, you can choose the reflective projection screen.
The meeting room of many units adopts the mobile projection method, and the projector is placed on the tabletop projection. At this time, the retro-reflective screen is very suitable.
Because the retroreflective screen requires the angle between the lens direction and the line-of-sight direction of the projector to be as small as possible, the projector is suitable for placement on the ground in front of the seat, on the coffee table, or on the rear wall above the head.
projection screen for type ultra-short throw projector
If it is a reflection type ultra-short throw projector, you must choose a directional reflection type special screen. Of course, if you are not very particular about the projection effect, you can choose the ordinary diffuse reflection screen, or even directly cast it on a white wall for viewing. The biggest advantage of the ordinary diffuse reflection screen is that it has no angle of view, the price is low, and there is no requirement for the installation position of the projector.
projection screen for the ceiling installationMost projectors are installed on the ceiling. According to the characteristics of the optical screen, you need to choose the reflective optical screen. This installation method can achieve the best results for the reflective projection screen, and if you choose the type Gray or black reflective optical screens can also play a good role in suppressing ambient light, and can achieve excellent projection effects in bright environments.
