Here is how to Connect U flash drive to projector.
1. Make sure the projector has a USB type A interface;
2. After confirmation, connect the U disk to the USB port of the projector;
3. Open the projector's file manager, find the U disk, and then access the files in the U disk.
The U disk is connected through the USB interface. There are many types of USB. The U disk adopts the USB-A interface, and the USB interface of the projector also has the design of the USB-A interface. Therefore, the projector can be directly connected to the U disk. If your projector cannot read the USB flash drive, you can consult the developer, or it may be that the product does not support reading the USB flash drive.
