How to Delete Apps on Smart TV (Samsung, LG, Sony, Vizio & More)
If your smart TV is cluttered with unused apps or you're trying to free up storage space, knowing how to delete apps on a smart TV is essential. Whether you're using a Samsung, LG, Sony, or Vizio model, this guide walks you through the exact steps for each brand—fast, easy, and accurate.
Let’s break it down by brand so you can find the method that works for your device.
Why Delete Apps on a Smart TV?​
  • Free up storage space
  • Improve performance and speed
  • Remove unused or outdated apps
  • Declutter the home screen
How to Delete Apps on Samsung Smart TV​
For Tizen OS (2017 and newer models):
  1. Press the Home button on your remote.
  2. Scroll to Apps, then select Settings (gear icon in top-right).
  3. Find the app you want to remove.
  4. Select the app, then choose Delete.
  5. Confirm deletion.
⚠️ Note: Some pre-installed apps (like Samsung TV Plus) may not be deletable.
How to Delete Apps on LG Smart TV​
For webOS:
  2. Navigate to the app list or launcher bar.
  3. Scroll to the app you want to delete.
  4. Press and hold the OK (wheel) button until the edit mode activates.
  5. A “trash bin” icon will appear—click it to delete the app.
💡 Tip: If holding the OK button doesn’t work, try selecting the app and using the remote’s up arrow to reveal the delete option.
How to Delete Apps on Sony Smart TV​
For Android TV (2015–2020 models):
  1. Press the Home button.
  2. Go to Settings > Apps > See all apps.
  3. Scroll and select the app to remove.
  4. Choose Uninstall, then confirm.
For Google TV (2021+):
  1. From the home screen, highlight the app.
  2. Press and hold the OK or Select button.
  3. Choose View Details, then select Uninstall.
How to Delete Apps on Vizio Smart TV​
For SmartCast TVs:
Unfortunately, SmartCast does not allow you to delete apps, as all available apps are pre-installed and managed via the cloud.
✅ Alternative: Use SmartCast's built-in casting feature to stream from your phone or install updates to refresh app availability.
How to Delete Apps on Roku TV​
  2. Highlight the app/channel.
  3. Press the Star (✱) button on your remote.
  4. Select Remove channel.
  5. Confirm removal.
How to Delete Apps on Fire TV / Fire TV Edition Smart TVs​
  1. From the Home screen, go to Settings > Applications > Manage Installed Applications.
  2. Scroll to the app you want to delete.
  3. Select it, then choose Uninstall.
  4. Confirm when prompted.
Frequently Asked Questions​
Can I delete built-in apps from my smart TV?​
No—most smart TVs restrict deletion of factory-installed apps like Netflix, YouTube, or system apps. You can usually hide them, though.
Will deleting apps speed up my smart TV?​
Yes, especially if your TV has limited memory. Removing unused apps can improve responsiveness and reduce freezing or lag.
Can I reinstall a deleted app later?​
Absolutely. Visit your TV’s app store or app hub, search for the app, and select Install.
Summary: How to Delete Apps on Any Smart TV​
BrandDeletion StepsNotes
SamsungHome > Apps > Settings > Select app > DeleteTizen OS required
LGHome > App list > Long press OK > Trash iconwebOS-based TVs
SonyHome > Settings > Apps > Select app > UninstallWorks for both Android TV and Google TV
VizioNot deletable, cloud-based SmartCastUse casting instead
RokuHome > Highlight app > ✱ button > Remove channelWorks across all Roku TVs
Fire TVSettings > Applications > Manage Apps > Select > UninstallSimple and fast
Related Reading:
How to delete apps on Fire TV?
How to Factory Reset Samsung Smart TV: Complete Step-by-Step Guide
