How to Get Netflix on a Non-Smart TV? Complete Guide
Want to enjoy Netflix on your older TV that doesn’t have smart features? Good news: You don’t need a smart TV to stream your favorite shows and movies. Here’s how to get Netflix on a non-smart TV in just a few simple steps.
This guide covers all working methods in 2024—whether your TV has HDMI or even just RCA ports.
Can You Watch Netflix on a Non-Smart TV?​
Yes, you can! You’ll just need a streaming device, game console, or casting setup that connects to your TV and gives you access to the Netflix app.
Your TV doesn’t need an internet connection itself—as long as the external device is connected to Wi-Fi, you’re good to go.
5 Easy Ways to Get Netflix on a Non-Smart TV​
1. Use a Streaming Device (Best Option)​
These plug-and-play devices are affordable and easy to use.
Recommended Devices:
  • Roku Streaming Stick
  • Amazon Fire TV Stick
  • Google Chromecast with Google TV
  • Apple TV (HD or 4K)
How to Set It Up:
  1. Plug the device into your TV’s HDMI port.
  2. Connect it to power (via USB or wall adapter).
  3. Use the on-screen prompts to connect to Wi-Fi.
  4. Download and open the Netflix app.
  5. Sign in with your Netflix account and start streaming.
💡 Most of these devices support 1080p and 4K streaming depending on your plan.
hdmi" >2. Connect a Laptop via HDMI​
You can turn your non-smart TV into a giant computer monitor.
How:
  1. Plug an HDMI cable from your laptop to your TV.
  2. Select the correct HDMI input on your TV.
  3. Open Netflix.com in a browser and play your content.
Works well for temporary use or travel, no extra device needed.
3. Use a Gaming Console​
If you already own a console, you don’t need anything else.
Compatible Consoles:
  • PlayStation 3/4/5
  • Xbox One / Series X|S
Steps:
  1. Connect your console to the TV via HDMI.
  2. Go to the console’s app store and install Netflix.
  3. Open the app and log in.
🔄 Many users prefer this method for both gaming and streaming on one device.
4. Use a Blu-ray Player with Streaming Support​
Modern Blu-ray players often include smart TV features.
Steps:
  1. Connect the player to your TV via HDMI.
  2. Make sure the player is connected to Wi-Fi.
  3. Access the Netflix app from the menu.
📀 Double duty for physical discs and streaming.
5. Use a Streaming Box with RCA Ports (for Very Old TVs)​
If your TV doesn’t have HDMI, try a streaming device that supports composite (red/white/yellow) output.
Options:
  • Roku Express+ (older model)
  • HDMI to RCA converter + any streaming stick
How it works:
  1. Connect the converter to the streaming device.
  2. Plug the RCA cables into your TV.
  3. Power on, switch to AV input, and set up Netflix.
🎯 This setup works even for CRT TVs!
FAQs: Netflix on Non-Smart TVs​
Can I use a USB to stream Netflix to my TV?​
No. USB ports on non-smart TVs are usually for media playback from flash drives, not streaming or screen mirroring.
Do I need a Netflix subscription?​
Yes. Plans start at $6.99/month with ads, and go up to $19.99/month for 4K. The app is free to install, but streaming requires a paid account.
Is screen mirroring an option?​
Yes, with devices like Chromecast or Miracast-enabled dongles. However, direct streaming using a remote control is usually more stable.
Final Thoughts​
You don’t need to buy a new TV just to enjoy Netflix. With one small add-on device, you can easily stream on your existing non-smart TV—often with better performance and more features than built-in apps.
Recap:​
  • Use a streaming stick (best all-around).
  • HDMI from laptop or console works great too.
  • For older TVs, try HDMI-to-RCA converters.
Related Reading:
How to Connect a Non-Smart TV to WiFi Wirelessly? Step-by-Step Guide
How to Get Netflix on Smart TV? Step-by-Step Guide
