how to install a fire stick on a samsung smart tv
KL111
Did you mean connecting firestick tv to Samsung smart TV? There should be HDMI ports on fire tv and Samsung tv, connecting them with an HDMI cable is the usual way to achieve your purpose.
  • Like
Reactions: THE
Kevinlll
If you want to connect the Amazon Fire Stick to your Samsung TV, there are the steps you can follow.
  1. First, connect the USB cable to the Fire Stick, and connect the other end to the power adapter to turn on the device;
  2. Then, use the HDMI port to connect the Fire Stick device to the Samsung TV;
  3. Turn on your Samsung TV and select the HDMI input channel that Firestick is connected to;
  4. After that, press and hold the Home button for 10 seconds, and use the Fire Stick to set the remote control. The Fire Stick will enter discovery mode, where the remote control will automatically connect to the device;
  5. Choose one of the WiFi networks and use the Fire Stick to connect to it by entering the password.
After completing these steps, you can register Fire Stick to your Amazon account, log in and enjoy your favorite movies and shows.
  • Like
Reactions: THE
THE
Thanks a lot!
