How to mirror iphone to LG TV?
Jemma
Mirror iPhone to LG TV with AirPlay
You can share screens directly from an iPhone to an Apple TV using Airplay. Airplay is the oficial screen sharing technology from Apple. There is how to use Apple Airplay.
1. Connect your iPhone to the same Wi-Fi network as your AirPlay 2-compatible smart TV.
2. Open Control Center:
  • On iPhone X or later or iPad with iPadOS 13 or later: Swipe down from the upper-right corner of the screen.
  • On iPhone 8 or earlier or iOS 11 or earlier: Swipe up from the bottom edge of the screen.
3. Tap Screen Mirroring
4. Select your AirPlay 2-compatible smart TV from the list.
5. If an AirPlay passcode appears on your TV screen, enter the passcode on your iOS device.
To stop mirroring your iOS device, open Control Center, tap Screen Mirroring, then tap Stop Mirroring. Or press the Menu button on your TV Remote.
Jemma
*Note: AirPlay is only supported from some Mac devices.
Supports:
  • iPhone 4 or later
  • iPad or iPad mini
  • iPod touch (4th generation or later)
You can stream content to these devices:
  • For photos and videos: Apple TV (2nd or 3rd generation)
  • For music: Apple TV (2nd or 3rd generation), AirPort Express, or AirPlay-enabled speakers
