LLLisa
Dangbei Mars Pro is equipped with 4G RAM running memory and 128G ROM storage capacity, which allows it to run smoothly and can be installed in many apps. If you have used it for a long time and there are too many apps that you don't use so regularly and want to clean the home page, there is a Reset function to achieve it.
First, turn back to the home page of Dangbei Mars Pro, navigate to the Settings icon on the up left corner and press OK to enter it.
Then, scroll down to find the System, enter it and scroll down, then there is a Reset button, click it.
Now, the Dangbei Mars Pro will restart and reset successfully, and you will get a brand new home page and clear storage!
