Samsung TVs support schedule viewing so that you can edit your TV time for watching, which is especially good for elders and kids. Here is the guide for you.
To set up a Schedule Viewing, you must first set the TV's clock, go to MENU>System>Time>Clock.
For setting up a scheduled viewing for analogue channel, follow these steps.
1. Go to MENU>Broadcasting>Schedule Manager.
2. Select Schedule>Schedule Viewing.
3. Specify the Source, Channel, Repeat, and Start Time options for the program you want to watch.
4. Then select OK to finish.
2. On the Scheduled screen, select a schedule viewing. A pop-up menu appears.
3. Select Edit. Change the time, days, or channel.
4. Select OK when done.
2. On the Scheduled screen, select a schedule viewing. A pop-up menu appears, then Select Delete.
3. Select OK in the pop-up menu, then the schedule viewing is removed.
Follow the guides above, you can set up watching time on your Samsung TV. You can set up a maximum total of 30 Schedule Viewing entries.
How to Set Up a Schedule Viewing on Samsung TV?
How to set up a scheduled viewing for a channel?
How to edit a scheduled viewing on Samsung TV?
How to cancel a scheduled viewing on Samsung TV?
