How to use the Sony projector remote control
Bread Pitt
development of Sony projectors is getting better and better, and the mini version of the projector has been withdrawn , and the sense of use is becoming more and more convenient. So how much is the price of Sony projectors? Many people still use traditional projectors. Instructions for sony projector remote control.
1. Description of Sony projector remote control
1. Align the projector with the screen and start it up;
2. After the self-test of the standby device is completed, check whether the size of the screen on the screen is appropriate; (if the screen is not covered, first adjust the distance between the machine and the screen to make the screen size basically match the screen)
3. Adjust the lifting knob at the bottom of the fuselage so that the upper and lower edges of the screen are flush with the screen (if the picture is too small, you need to adjust the focus of the machine or change the projection ratio)
4. Adjust the keystone correction (some projectors are not marked with keystone correction, you need to manually search in memu) to make the picture appear regular square;
5. Adjust the focal length to make the picture clear and bright;
6. After the basic completion, repeat the above process repeatedly with small movements until the standby screen is clearly covered on the screen;
7. Check whether the video cable is connected correctly, press Fn + switch key on the computer to switch the screen.
Second, how to set up the Sony projector
1. Press the "Menu" button to pop up the camera menu options, find the "Setting" option, press the OK button or Menu button to confirm entry.
2. Choose to display in other language. Open the "Setup Menu" , find the "Language" option, select the langurage item u need.
The above is about the price of the Sony projector, the related content of the Sony projector remote control, I hope it can help everyone!
for more projector information & knowledge, you can come to https://www.tvsbook.com/forums/projector.5/
