Indiegogo 4K Tri-laser Projector JMGO U2 Thread
moon42
I received a couple of emails from Indiegogo about this projector, a lot of reviewers have been saying that it works well, but this is my first projector and I am don't really understand all the specifications. I have also never used a laser projector before. Is this a good projector for home use?
  • UHD 4K resolution
  • 2400 ANSI lumens
  • 114% BT.2020
  • 9.4" Ultra short throw
  • Tri-color laser
  • Dynaudio speakers
  • Dolby surround sound, DTS-HD
  • MEMC & 3D
  • 100" image size (fixed lens)
  • <28 dB noise
Elena
Yes, JMGO U2 is a home laser projector that supports 4k. it focuses on the ultra-short throw, so you can cast a large screen in a very small room.
Robert
Its throw ratio is 0.25:1, which means that you can get a 100” projection when you put JMGO U2 9.5" from the wall. I think it's very suitable for a small room but requiring a big screen. totally a home cinema
Nadia
If you don't require too much on the high brightness, JMGO O1 is also a short-throw projector, good for home. But cheaper
58129166
Have you bought it? Is it good?
  • UHD 4K resolution
  • 2400 ANSI lumens
  • 114% BT.2020
  • Tri-color laser
  • Dynaudio speakers
  • MEMC & 3D
  • <28 dB noise
