InFocus IN2126a Projector: Can 3500 Lumens and Wireless Capability Transform Your Presentations or Just Add to the Noise?
Barend Ray
Active member
  1. 1 Spec
The InFocus IN2126a WXGA Network Projector presents an intriguing mix of specs and price point that challenges the conventional wisdom around what a solid projector should deliver. With a WXGA resolution and 3500 lumens, it aims to compete in environments where clarity and brightness are crucial. But in an age where 4K projectors are becoming more common, can a projector with these specs still hold its ground?
This device also boasts a 15,000:1 contrast ratio, which raises questions about how it performs in terms of color depth and detail compared to higher-end models. And let’s not forget the wireless capability—an essential feature for many today, yet often poorly executed in lower-priced options.
So, is this projector a smart choice for educators, business professionals, or home cinema enthusiasts who prioritize functionality without breaking the bank? Or is it just another underwhelming entry in a crowded market? Let's dive deep into the data and real-world performance to uncover whether the InFocus IN2126a truly delivers on its promises or falls short of expectations.
Spec​
InFocus IN2126a Projector​
InFocusIN2126aProjector.jpg​
$785​
Indoor/Outdoor​
WXGA (1280 x 800) resolution, 3500 lumens, 15,000:1 contrast ratio
15000:1​
1280 x 800​
1280 x 800​
3500 Lumen​
DLP​
4000 Hours​
Button Control​
2 watts​
Wireless​
Hardware Connectivity​
USB​
3D-ready​
Item Weight​
7.1 Pounds​
I'm considering the InFocus IN2126a WXGA Network Projector and would love some insights from those who've used it. The specs look solid with a WXGA resolution and 3500 lumens, but how does the picture quality hold up in real-world settings? Is the contrast ratio of 15,000:1 noticeable, especially in darker scenes?
Also, sound quality is a big factor for me. How do the built-in speakers perform, or would I need to invest in external audio? I’m curious about the system overall—does it integrate well with other devices, and is the wireless capability as seamless as it sounds?
Lastly, are there any downsides or quirks I should be aware of before making a decision? Your feedback would really help me out!
This projector is a solid deal! It hooks up great with the usual cables and even through USB, which is super handy. I’ve been trying to get the Wi-Fi feature to work on both Windows 10 and OS X (El Capitan), but no luck yet and support is pretty much nonexistent. I bought the Wi-Fi adapter they suggested because I really wanted to go wireless, but honestly, the projector itself does its job just fine. If you’re cool with WXGA resolution, you’ll be good to go. Plus, with 3500 lumens, it holds up pretty well in rooms that aren’t completely dark.
Radiohead
Still running one in a classroom, and the wireless module is the weak link—it drops constantly, so I just use HDMI. Brightness holds up fine after all this time though.
