Mi TV Stick 4K released: Support AV1 / VP9 hardware decoding
TV-Guide
It is reported that Xiaomi has launched its latest TV Stick product on its global website: Xiaomi TV Stick 4K. The appearance of the device is shown and its specifications and functions are detailed introduced.
As you can know from the name, the highlight function of Mi TV Stick 4K is to support 4K. The previous generation Mi TV Stick supports up to 1080p, so this alone is worth upgrading for users who own 4K TVs.
The Mi TV Stick 4K looks like a USB flash drive with dimensions of 106.8 x 29.4 x 15.4 mm and a weight of only 42.8g. One end is the HDMI interface to connect to the output device, and the other end is the MicroUSB interface to connect to the power supply.
In terms of configuration, the Mi TV Stick 4K uses an Amlogic S905Y4 processor, which is a quad-core A35 CPU with a Mali-G31 MP2 (850MHz) GPU. Supplemented by 2GB RAM, 8GB ROM, support dual-band Wi-Fi, Bluetooth 5.0, DTS HD, Dolby Atmos, Dolby Vision, support 4K60 frames 10bit AV1 / H.265 / VP9 P-2 / AVS2 hardware solution, pre- Install Android TV 11 system.
The device is also equipped with a physical remote control, which looks similar to the remote control included with the previous generation Mi TV Stick. The picture shows that it will have preset Netflix and Amazon Prime Video buttons, but these buttons can be changed for different regions. The remote control also has a dedicated Google Assistant button for voice commands. Due to the Android TV 11 system on the Mi TV Stick 4K, it supports Google Assistant.
At present, the official price of Mi TV Stick 4K has not been announced. The price of the previous generation 1080P version was 54.99 US dollars.
