Dramaqueen
Recently, NEC launched four new LCD laser projectors of the new NEC PA1004UL series at 10,000 lumen and 8,000 lumen entering engineering markets, helping the recovery and development of industries such as exhibitions, theme parks, performance theaters, and cultural tourism.
The new NEC LCD laser projectors NEC PA1004UL is equipped with a 0.8-inch 3LCD chip with WUXGA ultra-high definition resolution and a contrast ratio of up to 3,000,000:1, which can better display the bright and dark details of the picture. NEC PA1004UL series adopts advanced laser phosphor technology, which greatly improves the color gamut and brightness. It can achieve Rec. 2020 wide color gamut standard, and the color gamut coverage rate is as high as 90%. The bright and beautiful ultra-wide picture is extremely immersive and will bring a stronger visual impact.
At the same time, NEC PA1004UL also uses a new CQP cinema-level image processor, which provides support for 4K 60HZ ultra-high-definition high-frame rate images, bringing better and smoother picture display effects. Not only that, the new product also supports HDR high dynamic range technology, the color accuracy is higher, and the picture effect is more realistic.
NEC LCD laser projectors PA1004UL series:
multiple exclusive patented technologies
The NEC PA1004UL series supports 7*24 hours of uninterrupted operation and an ultra-long light source life of 20,000 hours, which reduces maintenance and use costs. The second-generation CCT fully enclosed internal circulation dust-proof heat dissipation technology adopted by the new product is designed to carry out all-round three-dimensional dust prevention for the core light engine part of the liquid crystal panel, and the refrigerant technology is used to achieve efficient heat dissipation. This technology makes it possible to abandon the traditional dust filter. Eliminate the subsequent operation and maintenance costs of replacing the filter. Combined with NEC's unique conflict-air cooling technology, it can not only accurately improve the cooling effect of the LCD panel, but also double the life of the LCD panel and polarizing plate.
Excellent heat dissipation performance brings stable and reliable operation, but also effectively reduces the noise during operation. Coupled with the top-notch patented noise reduction technology used, it can achieve an ultra-low noise level of 35dB during full power use, making its silent performance reach a new height, creating more opportunities for museums, immersive art exhibitions and other fields
The NEC PA1004UL new software platform features rich installation and debugging more flexible
In view of the current digital intelligent environment, the new NEC PA1004UL series further upgrades the software platform. The new NEC ProAssist projector assistance software platform can easily realize multi-machine control, remote management, edge fusion adjustment, image sub-region uniformity adjustment, gamma midtone adjustment and camera multi-machine color calibration. This software platform is The deployment of large-scale display devices and users who need to perform picture correction in integrated projects are undoubtedly even more powerful.
NEC PA1004UL series Product Specifications
Synchronization Range
Signal Compatibility/Connectivity
NEC PA1004UL series LCD laser projectors can be installed 360° in all directions freely, and provide up to nine different optional lenses, both with electric lens shift function, convenient for users to install and use. In addition, its built-in MST intelligent fusion and overlay function can complete the fusion or overlay operation in 5 minutes; and the 4K intelligent fusion display function provides a new low-cost, high-brightness 4K display solution.
Although affected by the epidemic in the first half of 2020, NEC has concentrated on strengthening product research and development and innovation, and constantly developing new products to meet market demand. Following the launch of its first 20,000 lumens DLP two-color laser product in early March, it also launched a 5,000 lumens DLP 4K laser projector in May, and then launched four new 3LCD laser projection products in one fell swoop. NEC has perfected DLP and 3LCD again. Full-line layout of two-way technology. As a leader in the laser projection industry, NEC will lead the development with a higher attitude and meet the diversified needs of users with high-quality products.
Aspect Ratio | 16X10 | Native Resolution | WUXGA 1920 x 1200 1920x1200 |
Maximum Resolution | 4K 4096 x 2160 | Contrast Ratio (typical) | 3,000,000:1 (with Dynamic Contrast) |
Horizontal (Analog/Digital) | Analog: 15-100kHz, Digital: 15-153kHz | Vertical | Analog: 48-120Hz, Digital: 24-120Hz |
Input Terminals RGB1(analog): VGA 15 pin D-sub, Component video using ADP-CV1E adapter RGB2(digital): HDMI (V2.0) w/HDCP (V1.4/2.2) RGB3(digital): HDMI (V2.0) w/HDCP (V1.4/2.2) RGB4(digital): DisplayPort w/HDCP (V1.3) RGB5(digital): HDBaseT w/HDCP (V1.4/2.2) Audio 1: Stereo Mini Jack | Output Terminals Audioout: Stereo Mini Jack Monitor Out: HDBaseT w/HDCP (V1.4/2.2) |
