ONOAYO AY3 vs Vision Mini Smart Projector: Which Offers Superior Portability and Connectivity for Your Outdoor Movie Nights?
  1. 1 Specs
  2. 2 Which to get
When it comes to mini projectors, the ONOAYO AY3 and the Vision Mini Smart Projector represent two distinct philosophies in portable viewing. The AY3 boasts a 360° tool-free adjustable stand and electric focus magic, promising ease of setup and sharp images on any surface. In contrast, the Vision Mini emphasizes its ultra-portability and flexible projection angles, along with advanced connectivity options like WiFi 6 and Bluetooth 5.2.
But which one truly caters to your needs? The ONOAYO's automatic keystone correction simplifies image alignment, while the Vision Mini's projection throw ratio offers remarkable flexibility in various spaces. As we dive deeper into their features, performance, and user experience, you'll see how each model stacks up against the other in the real world. Let’s explore the intricacies of these mini projectors and find out which one might be the better fit for your viewing habits.
Specs​
ONOAYO AY3 Mini Projector​
Vision Mini Smart Projector​
ONOAYOAY3MiniProjector.jpg​
VisionMiniSmartProjector.jpg​
$399.99​
$99.99​
Education, Home Cinema, Gaming​
Education, Bedroom TV/Mobile video Projector, Home Cinema, Wall Projector, Ceiling Projector, Overhead Projector, Business​
Power Cord*1, Mini Projector*1,Stand*1, User Manual*1, HDMI Cable*1, Remote*1(no battery included)​
💞360° Tool-free Adjustable Stand: This AY3 mini projector comes with a cool stand that can rotate 360° without any tools. Just pop it on a table or mount it on a tripod, adjust the angle however you like, and you're good to go!
🔃Auto Keystone Correction: Don't worry about weird-shaped images anymore. ONOAYO AY3 projector automatically corrects the trapezoidal distortion(vertical only), so your movies always look straight and sharp, even if you're projecting onto a wall or a funky supports vertical correction by remote.
✅️Electric Focus Magic: Forget about manual focus adjustments. With just a touch of a button, the AY3 movie projector magically adjusts the focus for you. Say hello to clear and crisp images every time, without any blurry moments.
【Convenience: 180 ° Rotation & Portable Size】 The Amornee Vision 1 Projector features a 180 ° rotation angle, making installation highly flexible. You can easily find the perfect screen target whether it’s on a horizontal wall or a vertical surface, and no matter if the desk is too tall or too low. The projector’s dimensions are 174.5 (L) x 124 (W) x 69 (H) mm and it weighs 500 g, making it lightweight and compact for easy portability.
【Trustworthy: 0.9:1 Projection Throw Ratio + Auto Keystone Correction & 1080P Resolution】 With a 0.9:1 projection throw ratio, the Amornee Vision 1 saves 1.74 ft of distance for a 100 ” screen, offering a projection size range of 40 to 100 inches from distances of 3.6ft to 17.7ft. It supports both 4:3 and 16:9 aspect ratios and has an 85% zoom out feature for a versatile viewing experience. The auto vertical keystone correction eliminates distorted images, ensuring alignment is never a concern. Supporting 720P Full HD native resolution and 1080P 4K, with a brightness of 160 ANSI and 8000 lumens, this projector delivers sharp, clear images with precise detail.
【Connectivity: Built-in Dual Band WiFi 6 + Bluetooth 5.2】 With dual-band WiFi 6 and Bluetooth 5.2, you can easily connect to the projector and enjoy a stable internet environment. The built-in speakers simplify your home setup, while high-speed WiFi and Bluetooth ensure high audio quality for a more immersive watching experience.
40 Inches - 300 Inches​
40 Inches - 100 Inches​
3.28 Feet - 19.68 Feet​
0.5 Meters - 10 Meters​
20000:1 Pixels​
2000:1 Pixels​
1980 x 1080 Pixels​
1280 x 720 Pixels​
1280 x 720​
20000 Lumen​
8000 Lumen​
LED​
LED​
Wireless, Portable, Built In Wi Fi​
Portable, Lightweight, Built-In Wi-Fi, Built-In Media Player, Short Throw​
H.264, H.265​
AVC​
30 Watts​
120000 Hours​
30000 Hours​
App​
Bluetooth/WiFi/HDMI/USB/3.5mm audi jack​
Bluetooth, Wi-Fi, USB, HDMI​
47 watts​
Mount Type​
Ceiling Mount/Tabletop Mount/Wall Mount/Ceiling Mount​
Tabletop Mount​
5.31"L x 4.64"W x 4.56"H​
5.27"L x 4.68"W x 6.43"H​
Which to get​
I’m torn between two mini projectors and could use some help deciding. Here’s the scoop:
**ONOAYO AY3 Mini Projector**: This one sounds super convenient with its **360° adjustable stand** and **auto keystone correction** for straight images. It also has this nifty **electric focus feature**, which means no more squinting at blurry images! But I’m curious about the sound quality—does it have built-in speakers that are decent? And how does the picture quality hold up, especially in less-than-ideal lighting conditions?
On the flip side, we have the **Vision Mini Smart Projector**. It boasts a **0.9:1 projection throw ratio** and supports **1080P resolution**, which sounds promising for crisp visuals. Plus, the **dual-band WiFi 6 and Bluetooth 5.2** connectivity is a nice touch for streaming. But, is it actually portable enough for casual use? And again, what’s the sound quality like?
I’m interested in any potential downsides you’ve noticed with either one, especially regarding picture and sound quality. Any thoughts?
