In addition to home theater audio/video systems, the popularity of karaoke systems is also quite high. The integrated video/K function seems to have become the norm in current audio and video solutions. In fact, singing is one of the most common ways of home entertainment. As a professional big brand, Peavey has also developed professional karaoke equipment for the home field in recent years, for example: MD12, MD10 two speakers, PHA-600 amplifier is designed for the home environment. Of course, these equipments are not enough to form a karaoke system, and they need to be equipped with SoundPower microphones and karaoke preamps.
Peavey SoundPower Home Karaoke System as small as possible
The advantage of reducing the size is that it is convenient to hide the speakers. That is because in the private audio-visual room, the karaoke speakers need to be hidden behind the projection screen like home theater speakers. Therefore, MD12 and MD10 reduce the thickness of the cabinet to fit the space behind the projection screen. At the same time, the inverted phase holes of the two speakers are installed on the left and right corners of the back panel to prevent the speakers from blocking the airflow too close to the rear wall, thereby affecting the bass energy. In terms of binding posts, they both have a Canon interface and a screw interface. On the one hand, the wiring method is more flexible, and on the other hand, the screw interface can also save rear space.
In terms of the speaker unit, both the MD12 and MD10 use coaxial units (12 inches and 10 inches, respectively), which can shorten the height of the front baffle to a certain extent compared to the design of the separate installation of the high and low units, and the coaxial The advantage of the unit is that it can realize the approach to the point sound source. In terms of application, the designer recommends the use of a 4-channel method to build a karaoke system with the best results. Among them, the front main channel uses MD12 to achieve a stronger sound pressure level and bass energy, and the rear uses MD10 as an auxiliary to enhance the atmosphere of the scene. As for whether you need to add additional subwoofers, it depends on the customer or the needs of the environment to choose.
Peavey SoundPower Home Karaoke System warm, thick and comfortable
After adjustment, the sound is very warm, the sound in the middle and high range is very smooth, the bass is relatively clean and strong, and the overall sense of listening is still very comfortable. In terms of singing performance, the thickness and clarity of the sound are quite good.
To sum up
This set of home karaoke systems composed of Peavey and SoundPower equipment is compatible with home theater and karaoke at the same time. But in its key karaoke function, it not only optimizes the sound for ordinary users, but also meets the requirements of engineering staff in terms of function, providing greater and more adjustment space, so as to adjust to meet the needs of customers. K song effect. In terms of sound effects, the sound of this karaoke system is warm, audible, low-frequency power is good, and clean, and the effect of vocal singing is not lacking in thickness and clarity.
Basic technical parameters of Peavey MD12 Karaoke Speaker
Speaker type: 12 inch 2 frequency division 2 unit inverter type speaker
Frequency response range: 55Hz-18kHz (-6dB), 65Hz-16kHz (±3dB)
S P L (1w @ 1m): 97dB S P L ma x (@ 1m): 128.5dB@1400w
Rated impedance: 8Ω
Rated power: 350W
Maximum power: 1400W
Coverage: 90°×90° (H×V)
Surface treatment: high-strength abrasion-resistant water-based paint
Dimension (WxDxH): 390mm×325mm×550mm
Net weight: 21.4kg
Reference price: 11950 yuan /per unit
To sum up
Rated impedance: 8Ω
Rated power: 350W
Net weight: 21.4kg
