kingofmyheart
Dangbei H1 is equipped with huawei haishi quad-core processor, 2GB storage + 16GB flash memory, ad-free, which can be said to be a featured TV box with high cost performance. Then how does Dangbei H1 box actually perform?
Start from the packaging, Dangbei H1 box packaging USES the white + bottom blue design, simple and beautiful.
Dangbei H1 box is still a continuation of the previous generation of black and white color design, but the body of the body is pure white, size of 3.7in*3.7in*0.6in(95mm*95mm*16mm), rounded edges, the front of the body engraved with a "Dangbei" LOGO, only the size of the palm of the body, the whole appears light and delicate.
Both sides of Dangbei H1 box fuselage adopt asymmetric black line design, the front of the box is 4 interfaces, the bottom of the fuselage is mainly a circle of cooling holes and a circle of black non-slip pad.
In addition to the box, it also comes with a black remote with a bluetooth voice button and a simple layout.
Specs
Dangbei H1 box is equipped with huawei 4 core 64-bit processor, the CPU frequency is 2.0 GHz, this chip will not slow down at high temperature, in addition, Dangbei H1 box adopts 2G DDR3 + 16G eMMC memory combination, when the author runs the box daily, it is obviously "light and carefree" to use.
Dangbei H1 box supports network 2.4g /5G dual-frequency network, with double antennas, strong signal reception, faster and more stable TV network speed. Dangbei H1 box supports low power bluetooth 4.2, lower power consumption, and data transmission is really stable and fast.
Dangbei H1 box is equipped with HDMI 2.0 interface, USB2.0 interface, AV video and audio interface and power socket, which can be flexibly applied to various TV sets, game consoles and monitors. It can be said that it is very friendly for fans of 3A games and movies.
Audio and picture test
Dangbei H1 box is equipped with hifi-level stereo sound output, supporting external power amplifier; The bottom noise is less than 10uVRMS, the frequency response 20-20khz curve smoothness is more than 95%, THD+N total harmonic distortion + noise is less than 1%, the sound quality effect is not inferior to that of ordinary speakers.
Dangbei H1 box in the picture quality performance is surprising, it supports 4K HDR10 dynamic display technology, and also supports 4K video decoding, combined with Dangbei self-developed picture quality engine, picture image, quality restoration is clear and accurate.
In addition, Dangbei H1 box this time also brought two new black technology, DVFS technology (dynamic frequency modulation and voltage regulation), AVS technology (automatic voltage regulation), with the 4 core processor, after the author's actual 4K HDR demo segment test, these two new technologies enable H1 to perform very well in different use of screen scenes.
Dangbei H1 box with "FindMe (find my remote control)" function, and support bluetooth remote control, mobile phone remote control and AI voice intelligent control three control methods, among which AI intelligent voice control voice recognition ability is very accurate, as long as you tap the remote control to speak the requirements can easily watch TV.
Specs
