Roku Plus Series TV: Is Stunning 4K QLED Clarity Worth the Price of Seamless Streaming and Advanced Voice Control?
  1. 1 Spec
When you think of a smart TV, what comes to mind? Is it the promise of a seamless viewing experience, or perhaps the endless battle against confusing interfaces? Today, we're diving into the Roku 65-Inch Plus Series 4K QLED Smart TV, a product that positions itself as the “smart TV that makes sense.” But does it really deliver on that promise, or is it just another contender in an already crowded market?
On the surface, this TV boasts impressive specs—4K resolution, Dolby Vision, and that alluring QLED display. It’s designed to make your viewing experience as effortless as possible, with features like automatic brightness and a voice remote. But let’s peel back the layers. In a world where every brand claims to have the best viewing experience, what does it mean for a TV to actually make sense? Is simplicity enough to justify its place in your living room?
Join me as we explore whether this Roku model is a genuine contender for your attention or just a shiny new gadget that might leave you wanting more. Let’s see if it lives up to the hype or simply adds to the noise.
Spec​
Roku Plus Series TV​
RokuPlusSeriesTV.jpg​
65 Inches​
$578​
Model Year​
2023​
Specific Uses​
Home Viewing​
Stands and screws, Cable management clip, Voice Remote Pro with charging cable, Roku 65" Plus Series QLED 4K Smart TV, Quick Start Guide​
The smart TV that makes sense: Roku Plus Series TVs are thoughtfully designed by Roku to give viewers a premium entertainment experience at an incredible value.
Made by Roku: From the brand you trust to make streaming easier comes a thoughtfully designed 65-inch smart TV powered by the delightfully simple Roku experience.
Breathtaking 4K & auto brightness: Stunningly sharp 4K resolution brings out the rich detail in your entertainment. Avoid fiddling with settings with a screen that automatically adjusts based on your room’s lighting.
Colorful QLED screen: Watch strikingly accurate hues pop off the QLED screen with an expanded color palette and increased brightness.
See it to believe it: Experience eye-popping detail in spectacular color, contrast, and brightness with Dolby Vision and HDR10+, plus sharp contrast with local dimming for vivid highlights and deep darks.
Operating System​
Roku OS​
Internet Applications​
Netflix, Disney Plus, Prime Video, Hulu, Apple TV, Plus 1000s More​
Bluetooth​
Remote Control, App Control, Voice Control​
App​
Aspect Ratio​
16:9​
Display Technology​
QLED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
60 Hz​
HDR Format​
Dolby Vision and HDR10+​
Backlight Technology​
LED​
Backlight Setting​
Dimming​
Backlight Configuration​
Direct-Lit​
Dolby Vision®, QLED​
Audio Channels​
4.1​
Surround Sound​
Dolby Atmos​
Audio Output​
[INF]​
Audio Input​
HDMI, USB, 3_5_mm_audio (which is compatible with RCA), but not Optical or Coaxial​
Speaker Description​
Dolby Atmos certified, designed for clear speech and louder sound​
H.264, H.265 (HEVC), VP9​
Screen Mirroring​
AirPlay 2, Miracast​
Tuner Type​
ATSC​
Bezel-Less Design, Local Dimming, HDR10+, Ambient Light Sensor, Dolby Vision​
Mount Standard​
400 x 300 mm​
Wi-Fi, USB, Ethernet, HDMI​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
1​
HDMI Ports​
4​
Connector Type​
Ethernet, HDMI, USB, Wi-Fi​
Signal Format​
Dolby Vision, HDR10+, HLG, Digital​
Hardware Interface​
Bluetooth, USB, Ethernet, 3.5mm Audio, Composite Video​
D x W x H​
13.1"D x 57"W x 35.9"H​
Item Weight​
49.6 Pounds​
I'm considering the Roku Smart TV - 65-Inch Plus Series with 4K QLED and I could use some advice before pulling the trigger. I've heard great things about the picture quality, especially with the Dolby Vision and HDR10+, but how does it really perform in everyday use? Is the color accuracy and brightness as impressive as advertised?
Also, I'm curious about the sound quality. Does it hold up well, or would I need to invest in a soundbar for a better experience?
I've read that the Roku interface is user-friendly, but does the system run smoothly over time? Are there any potential downsides I should be aware of, like issues with streaming or connectivity?
Thanks in advance for your insights!
