If you are thinking between choosing a Samsung or LG LCD, you need to read this article. Over the year, both brands have established a track record of durability and quality. For this reason, it might be difficult for you to make an informed decision on which brand will perfectly suit your needs.
Samsung and LG releases trendy new models of smart TV's occasionally. typically, every new model is expected to have enhanced visual, overhauled processor and larger panels. both brands are top competitors in the television manufacturing industry and have scaled a competitive market with the high-end user interactive product available in the market today.
To consider technical differences between both brands, we need to examine the following categories.
Smart TV Platforms
Both LG and Samsung have distinct user interface making them unique in style. LG incorporated the use of webOS - a stripped-back, minimal smart TV interface.
LG webOs commonly uses a horizontal menu bar for app navigation. the menu bar is also customizable; this enables you to easily place your favorite apps where you
want them situated on the dashboard.
while Samsung's Tizen platform is not so different in layout, it doesn't have a search algorithm that is as impressive as LG'S ThinQ AI software.
Voice Assistants
LG's Super UHD sets come with an in-built Google assistant with limited compatibility with Alexa-based devices, while Samsung uses its own in-built Bixby assistant (which is somewhat inferior) with the option to interface with Google Assistant or Alexa third-party devices.
Panel Technology
There are two predominant panel technology in the premium television market; the QLED and the OLED. OLED represents Organic Light Emitting Diode and emits light without an external light source shining through it. This gives the ability to regulate the brightness level of each pixel.
OLEDs, originally manufactured by LG display, are known for their vibrant colors and low brightness.
QLED, however, is a proprietary technology developed by Samsung. It uses quantum dots to improve its color and contrast. QLED TVs are significantly brighter than OLEDs, even though this can limit their ability to show both bright and dark images simultaneously.
It is safe to say that LG's OLED is generally more suitable for viewing high-quality videos in dark areas. Samsung’s QLED sets lag on contrast but have a very bright display.
SAMSUNG VS LG LCD: Which Should you Choose?
Both companies serious focus on improving their display technologies; however, the set you choose will depend on what you want brings better viewing satisfaction. Samsung should be your favorite pick if you want a bright dazzling screen to light up your home. If you desire an LCD with the most impressive display quality, your best bet is the LG's OLED panels
Smart TV Platforms
Voice Assistants
Panel Technology
