Many people want to buy a big size screen TV but don't know which one is better for home. The Samsung QLED TV Q60A series and Q70T series are really popular with their 85-inch versions. When Samsung TV Q60A VS Q70T, which one is better? Let's have a comparison and find out the better one.
What's more, Samsung Q70T has FreeSync variable refresh technology while the Samsung Q60A does not. As for the input ports, both of them have a T-Type port and three HDMI ports, but Samsung Q70T has a more HDMI port for the antenna connection.
Both these two TVs have Bluetooth, but they are for different connections. The Samsung Q60A is for the keyboard while Samsung Q70T is for the audio output. Therefore, Samsung Q60A can be connected to a keyboard with Bluetooth while Samsung Q70T doesn't.
As for the virtual assistant support, although both support Amazon Alexa and Samsung Bixby, Samsung Q60A also supports Google Assistant when compared to Samsung Q70T. What's more, Samsung Q60A also support auto low latency mode while Samsung Q70T does not.
The Samsung Q60A is its entry-level QLED model, which is an LCD TV with quantum dots. These magic points allow the Q60A to perform better than many traditional LCDs that cost less, brighter, deeper, and richer in HDR content. The new Samsung Q70T QLED TV has most of the features found in Samsung's more expensive QLED 4K screens, but doesn't come with such a high price tag - a great one for those looking for a good value TV, and it's also my choice for today's comparison.
Samsung Q60A 85' | Samsung Q70T 85‘ | |
Price | $2,199 | $1,679 |
Display Technology | Quantum Dot LCD | Quantum Dot LCD |
Resolution | 3840 x 2160 (4K) | 3840 x 2160 (4K) |
Lighting System | Not Specified | Backlit LED |
HDR Compatibility | HDR10, HDR10+, Hybrid Log-Gamma | HDR10, HDR10+, Hybrid Log-Gamma |
Variable Refresh Technology | None | FreeSync |
Input Ports | 3 x HDMI Type A 1 x F-Type (RF Antenna) | 1 x HDMI Type A (HDMI 2.1) 3 x HDMI Type A (RF Antenna) 1 x F-Type (RF Antenna) |
Output Ports | 1 x TOSLINK Optical (Digital Audio) | 1 x TOSLINK Optical (Digital Audio) |
Bluetooth | Bluetooth 4.2 (Keyboard) | Bluetooth 4.2 (Audio Output) |
USB Ports | 2 x USB 2.0 | 2 x USB 2.0 |
Speaker | 20 W | 20 W |
Virtual Assistant Support | Amazon Alexa, Google Assistant, Samsung Bixby | Amazon Alexa, Samsung Bixby |
Auto Low Latency Mode (ALLM) | Yes | No |
Samsung QLED TV Q60A VS Q70T 85inch: What's the same?
From the comparison chart, we can see that Samsung Q60A and Samsung Q70T have the same screen display technology as Quantum Dot LCD( or QLED, Quantum dot LED), which are essentially a new type of LED-backlit LCD, and they make use of tiny phosphorescent crystals to react to light and electricity. They both have 4K resolution and the same HDR compatibility of HDR10, HDR10+, and Hybrid Log-Gamma. What's more, they have the same USB ports and the same speaker of 20W. These make them a good performance on the market of QLED big screen TV market, and that's why many customers choose them as an entertainment helper at home. Actually, they are well worth buying if you are really looking for an 85 inch TV.Samsung QLED TV Q60A VS Q70T 85inch: What's the difference?
First of all, the price is a factor that many people are really concerned about. Samsung Q60A is priced at $2199, which is a little more expensive than the Samsung Q70T of $1679. In addition to the price, the Samsung Q70T is equipped with a backlit LED lighting system while the Samsung Q60A is not specified.What's more, Samsung Q70T has FreeSync variable refresh technology while the Samsung Q60A does not. As for the input ports, both of them have a T-Type port and three HDMI ports, but Samsung Q70T has a more HDMI port for the antenna connection.
Summary
