Robert
The new 4K Signyean projector is powered by Huawei Hiss 64-bit processor, built-in Android 9.0 system, 1080P resolution, 650ANSI lumen brightness, and is now available for sale online.
1. The optical performance of Signyean 4K ultra HD new projector, its true resolution does not reach 4K, the physical resolution is 1080P, only supports 4K; The projector adopts LCD technology, built-in 5-inch LCD panel; LED four-channel light source, brightness up to 650ANSI lumens; The lens is high light transmittance coated lens.
2. System: Built-in Android 9.0 system with built-in massive application market and it supports third-party software installation. At the same time, Signyean 4K projector covers the entire network resources of iQiyi and automatically recommends high-quality film and television content; Customized UI. But the configuration ratio is not too high. It runs on a Huawei Hiss 64-bit processor and has only 1GB of ram and 4GB of storage.
3. Interface parameters: The expansion interface of Signyean projector is relatively rich. Signyean 4K Ultra HD projector is equipped with dual USB2.0, dual HDMI, AV video interface and 3.5mm audio output interface; It can basically meet the needs of external expansion, but there is no LAN network interface.
4. Performance, Signyean projector has built in double speakers, and it supports stereo surround sound and 5.1 surround sound, to provide a shock sound quality effect. Support wifi connection, configure 2.4g +5G dual-band wifi, can realize wireless display. In addition, Signyean projector supports intelligent voice, and the intelligent voice system can be directly controlled by voice commands. Watching movies, listening to songs and telling stories can be done orally.
To sum up, there is no bright point in the parameters of the new Signyean projector, what can attract consumers should be the processor chip, after all, it uses Huawei China core, but the memory configuration is a little too small, 4GB of storage space is completely insufficient, and the high configuration of the F3 has 4GB of running memory. If your budget is low and use requirements are not high, may consider this product.
