Daniel
Although the Sony projector is expensive, its performance and configuration are excellent. Here are some precautions for installing and using Sony projectors.
Poor ventilation
Reason: The surrounding area where the Sony projector is installed is filled with other debris and clogging the vents, which will cause heat to accumulate inside the projector, the temperature to soar, trigger a temperature alarm, prompting the temperature to be too high, and then automatically shutting down.
Solution: Ensure that there is more than 50cm of space around the Sony projector, ensure that there are no objects blocking the ventilation holes nearby, and clean the projector regularly.
High temperature and high humidity environment
Reason: The Sony projector is installed in a high temperature or high humidity environment, because the temperature sensor of the Sony projector is very sensitive and it is prone to false alarms. Installing in a place with excessive humidity and high temperature can easily cause the projector to malfunction.
Solution: Do not install the Sony projector in a place with high temperature and high humidity, but in an environment with suitable temperature and humidity.
Dusty places
Reason: In a large amount of dusty environment, the filter screen of Sony projectors is easy to be blocked, which causes problems in the heat dissipation of Sony projectors, resulting in an increase in internal temperature and loss of components.
Solution: Ensure that the installation environment is tidy and clean the air filter of the Sony projector regularly.
Precautions for the use of Sony projectors
1. Use in high altitude areas
If you use a Sony projector at an altitude of more than 1500 meters, you need to turn on the "High Altitude Mode" in the menu. If this mode is not turned on, it is easy to cause problems with some components of the Sony projector.
2. Tilt the projection
When the Sony projector is falling, remember not to use the projector, otherwise it will easily cause malfunction.
3. There are obstructions in front of the lens
During the projection of the Sony projector, do not place objects that block the light in front of the projection lens, because the temperature of the projected light is very high and it is easy to damage the objects.
These are the notes for the installation and use of Sony projectors. I hope everyone pays more attention when using and installing the projector, so that the service life of the projector can be effectively improved.
Poor ventilation
Dusty places
