EmmaStone
TCL 40s325 Smart Roku TV is the second LED best seller on Amazon US. A lot of users are satisfied with TCL 40s325 Smart Roku TV for its good quality with a nice price (less than $ 200). However, there might be some common problems while using the model TCL Roku TV, here I list the 6 most common trouble and their solutions, hope these would help owners of this TCL 40s325 Smart Roku TV :
TCL Smart Roku TV | 6 Most Common Problems and Solutions
1. How to get a larger picture?
• Play your movie/video and press the (*) asterisk button.
• Select Picture Size on your TCL 40s325 Smart Roku TV , select the picture size of your preference.
2. Is it with Bluetooth? How to connect my headset / sound bar?
Currently, the TCL 40s325 Smart Roku TV does not support Bluetooth.
TCL 40s325 Smart Roku TV will connect your speaker or soundbar by the Roku app, pairing it with your phone, and enabling "Private Listening". The app will only activate Private Listening mode when streaming net stream content, NOT something played from any other source, such as a media player. So if you're only streaming stuff, fantastic; if you're watching from a media player or other source, guess you'll have to try your luck with a transmitter.
3 What to do if cannot connect to Wi-Fi?
5. Cannot connect cable/satellite box or antenna through a coax cable
- Select the correct wireless network name and verify the password entered on TCL 40s325 Smart Roku TV (case sensitive).
- Relocate the router from objects that interfere with performance (cordless phones, baby monitors, etc. ).
- Reboot the TCL 40s325 Smart Roku TV by disconnecting the power for more than 2 minutes and reconnect
- Download the Roku app to your phone or tablet through Google Play or iTunes.
- Simply search for “Roku App” and choose the Roku app by Roku Inc.
- Follow the onscreen prompts,
The free Roku app allows you to use your mobile device as a full functioning remote control with voice search & keypad
- For best performance, use the HDMI connection. If not available, then:
- Make sure the cable connections to the TCL 40s325 Smart Roku TV and your device are securely fastened.
- Select cable/satellite box or antenna TV input on TCL 40s325 Smart Roku TV .
- Select “start finding channels” and follow the on-screen instructions on TCL 40s325 Smart Roku TV to perform a full channel scan.
- click the home button to take you to the home screen
- go to settings
- go to system,
- go to power, you will find an option to turn off the standby LED light.
