LouiseWinner
Is the TCL 50S425 Roku TV worth buying? Does it have any advantages or disadvantages? Let's have a look.
The 50 inch TCL 50S425 Roku TV specification:
Dimensions (W x H x D): TV without stand: 44. 1 X 25. 7 X 3. 2 inches, TV with stand: 44. 1 X 28 X 8 inches.
Inputs: 3 HDMI 2. 0 with HDCP 2. 2 (one with HDMI ARC), 1 USB (media player), RF, Composite, Headphone Jack, Optical Audio Out, Ethernet.
Resolution: 4K Ultra HD
Display: 120Hz CMI effective refresh rate, HDR10
CPU: Dual-core
GPU: Dual-core
Voice: Alexa and Google Assistant
Audio: 2 Channel x 8W audio power, Dolby Digital Plus
Warranty: 1 year limited warranty
Weight: 23.6 pounds
Price: $320 for reference
TCL 50S425 Roku TV Review: advantages
1. Easy to use. Have your phone/tablet or a computer nearby to enter the code on the website to activate. The tv detects what else you connect and prompts you to enter what it is, which makes it simple to switch over to satellite, Fire tv stick, or whatever else you connect.
2. Picture quality, sound and overall brightness are all very good for the price. Blu Rays and "Ultra HD" Netflix look excellent.
3. The ROKU TV had lots of free channels.
TCL 50S425 Roku TV Review: disadvantages
1. The power cord is shorter than I need and it connects on the left rear of the TV while the 3 HDMI ports etc are on the right side behind the screen.
2. Some weird pixelation when viewing certain colors of purple and bright red.
3. Roku remote does not have a ton or buttons.
4. Bad side viewing angle. The wider the angle, the more the picture degenerates into a contrast-free blur.
5. The TV light is too bright at dark under the TCL logo.
CPU: Dual-core
GPU: Dual-core
Weight: 23.6 pounds
