Gabe
All high-power electronics have a problem to solve, and that is the heat dissipation of the device. The same is true of smart projectors, the heat dissipation is very important.
Let us learn the impact of overheating to the projector.
1. Impact on projection brightness and color
As most of household smart projectors now use LED light sources, projector overheating will cause a serious impact on brightness and color. That is because the red light source in the LED light source is particularly affected by temperature, too high or too low temperature will make it lose brightness, this time the LED green light source and blue light source in order to maintain color balance will reduce brightness, with the reduction of the brightness of the primary color light source, the brightness of the projector is naturally low. And if the green and blue light sources do not reduce the brightness the first time to maintain the color balance, then the color of the projected picture will be biased.
