Gabe
ViewSonic R3 projector has been released recently, which is portable and small. It has 1080P full HD resolution and a number of technical upgrades, so let's see the ViewSonic R3 projector review.
Appearance Design
The space layout and cooling air duct design of ViewSonic R3 portable projector is reasonable which maximizes the use of limited space, so the body is very small (weight only 0.71Kg, body size 228mm×121mm×35mm). Body modeling is simple with natural color matching, can easily integrate into different use environments, and is in line with the aesthetic of young people.
Small and convenient to carry around
There's a stand on the bottom
Interfaces on the back
Built-in large capacity battery, can charge mobile devices
Viewsonic R3 portable projector has a stand at the bottom of the body, while reserving a screw hole to connect to the tripod. The built-in 9000mAh large capacity battery can last up to 2 hours in power-saving mode, enough to watch a movie. In addition, it can be used as a portable power source to power other devices when you are outside.
Appearance Design
