ViewSonic Y5, which was launched recently, is an intelligent projector that integrates efficient office work and high-brush gaming. Different from ViewSonic's previous models, the ViewSonic Y5 projector is equipped with an intelligent operating system, so how is its picture effect?
ViewSonic Y5 projector adopts RGBG four-channel LED long-term light source and 0.65DMD display chip. In terms of brightness, ViewSonic Y5 has a high brightness of 3000 lumens. In terms of resolution, it adopts WXGA (ie 1280*800) resolution, 16:10 widescreen display, 125% REC.709 color gamut and 10bit color depth.
ViewSonic Y5 has built-in Android 9.0 smart operating system. Just connect to the Internet and watch TV shows and movies. As a high-brush gaming projector, it also has an exclusive game mode, 120Hz high refresh rate and 16ms low-latency picture, bringing a smooth experience.
ViewSonic Y5 uses 1.3x large zoom, and built-in 0.8-2.0x electronic zoom, supports 360° projection, making installation more flexible. In addition, it also supports four-way screen correction, 40-degree screen correction up and down, left and right, and always maintains a clear and square screen effect for easy placement.
The ViewSonic Y5 projector is equipped with a smart backlight Bluetooth remote control, and the backlight automatically turns on when you pick it up. Support 2.4GHz/5GHz dual-band WiFi, high transmission rate. In addition, it also supports HDMI CEC one-button start, Blu-ray 3D and AI voice recognition functions, which can diversify the viewing experience of video and audio.
Compared with traditional projectors, ViewSonic Y5 has added functions such as intelligent operating system on the original basis, enriching and expanding more new experiences.
1. Optical display
2. System function
3. Projection range
4. Specifications and accessories
5. Summary
