What are Sony Laser Projector VPL-C500XZ and VPL-C500WZ's differences? Which is better?
Bread Pitt
Recently, Sony announced that it will release two new VPL-C500XZ and VPL-C500WZ laser projectors , which will be available for the Chinese market in April 2020. The Sony laser projectors C500XZ and C500WZ are both 5000 ANSI lumens. They use a laser light source technology system combined with a 3LCD system. They are all equipped with high-end engineering machine setting modes, which can adjust parameters such as image and light source brightness. , So what is the difference between the Sony VPL-C500XZ and VPL-C500WZ laser projectors? Which is better? The following is a comparison between Sony C500XZ and C500WZ in terms of parameters and usage:
The main differences between Sony VPL-C500XZ and VPL-C500WZ:
  • Resolution: Sony VPL-C500XZ resolution is XGA (1024 × 768 pixels), Sony VPL-C500WZ resolution is WXGA (1280 × 800 pixels);
  • Chip specifications: Sony VPL-C500XZ uses a 0.63-inch LCD panel, and Sony VPL-C500WZ uses a 0.64-inch LCD panel;
  • Projection ratio: The projection ratio of Sony VPL-C500XZ is 1.41: 1, at least a distance of about 2.9 meters is required to project a 100-inch screen; the projection ratio of Sony VPL-C500WZ is 1.29: 1, and the minimum projection distance is only about 2.8 meters at a distance of 100 inches
Overall, the Sony VPL-C500WZ has better parameter configuration than the Sony VPL-C500XZ. The Sony VPL-C500WZ has a higher resolution, a larger display chip, and a smaller projection Than, can adapt to higher use needs. It is understood that the pricing of these two products has not yet been released. After the launch in April 2020, interested friends can pay attention to these two products.
