MediaTek MTK9679 is MediaTek's latest big screen end processing chip, compared to its predecessor MTK9669 chip has a lot of enhancements. So what are the features of the MediaTek MTK9679 chip?
The MediaTek MTK9679 chip is a high-performance processing chip developed by MediaTek, with a Cortex-A75 processor on the CPU side. In terms of architecture, the Cortex-A75's decoder is basically the same as the Cortex-A73's, and they are both capable of decoding the vast majority of instructions in a single cycle.
The Cortex-A75 can deliver 2uops per release queue, and the ALU and AGU are designed with exclusivity to improve efficiency. This allows the use of the Cortex-A75 to have a greater advantage in the speculative nature of instruction execution. In terms of peak performance, Cortex-A75 can boost up to 8uops per pipeline, significantly outperforming its predecessor.
GPU, the MTK9679 chip uses the G52 graphics processor in Mali's third-generation G series. It has a faster processing channel and is a more moderate level of performance and power consumption. This is not much different from the performance of the previous generation of T820, T830, the new generation of G51.
1. The MediaTek MTK9679 chip is a much improved chip compared to the MTK9669 chip, with the biggest feature being that it solves the problem of not supporting USB3.0. This allows the projector to be equipped with a USB3.0 interface that provides high speed transfer efficiency, therefore allowing the projector to play U disk videos more smoothly and avoid lagging.
2. Also, the MediaTek MTK9679 chip allows the device to support WIFI6, giving the device a better network effect.
3. In addition, the MediaTek MTK9679 chip can still provide powerful performance, supporting screen avoidance, automatic screen entry and other functions.
The MediaTek MTK9679 chip is not yet in full use. The popularity of the MediaTek MTK9679 chip will make the projector more practical and bring a better viewing experience for people.
What is MediaTek MTK9679 chip?
CPU processor
GPU processor
What are the features of MediaTek MTK9679 chip?
