What do you think about the SONY's PS5 console cooling solution?
Jamsbond
Recently, SONY's PS5 console was revealed to have a patent on its radiator. It looks like the PS5's cooling solution is similar to that of the Xbox One X, using a heat sink. The cooling scheme is obviously different from the PS4's current design, which may partly reflect the PS5's cooling system. According to the patent, it is a radiator with an internal conduction path, allowing heat to pass directly from the SoC to the cooling system, ensuring optimal heat dissipation without drastically changing the configuration of the host.
Another part of the radiator design, similar to the Xbox One X, has conductors going through holes in the PCB and connected to another thermal solution. The Xbox One X has a similar layout, with a radiator on One side and a heat-regulating X clip on the other.
Since PS5 architect Mark Cerny had assured fans that they would be satisfied with the PS5's cooling system, I am looking forward to it.
