What should I pay attention to when choosing a projector? When choosing a projector, you need to consider important parameters such as brightness, resolution, system configuration, and throw ratio. For details, please refer to the following notes.
1. Select the projector to look for brightness and resolution in the display parameters. Brightness is based on ANSI lumens or lumens as much as possible. ANSI lumens are mostly used in home smart projectors, and lumens are mostly used in projectors with bulb light sources. Remember that light source brightness or other units of brightness are not standardized.
2. The resolution needs to be based on the size of the projector's display chip. (check the relationship between projector resolution and display chip)
Projectors with DLP display technology can check the size of the DMD display chip. Projectors with LCD display technology can check the size of the display panel. The larger the display chip, the higher the resolution.
3. Most of the smart projection systems are Android system. Of course, the higher the configuration, the better the projector with more memory. The projection ratio affects the placement of the projector. Generally, the projection ratio within 1.3:1 is suitable for home use.
